peach495
Dec 26, 2016Tutor
WiFi problems w/ R7000
I've had this WiFi for awhile without issues runing multiple items through it. Recently I attempted to attach an Amazon firestick to our Smart TV because it predates Amazon Prime. The onscreen menue ...
- Jan 03, 2017
Thank you everyone for all your suggestions. I had to buy a new router & am no longer trying to fix this one.
Dec 26, 2016Guru - Experienced User
You might as a suggestion, have someone from here in the forums or maybe a forum moderator use teamviewer and work with you and have them check your wireless settings on your router. IT's safe to use and is secure way of allowing someone trusted to help you have a look at your router.
peach495
Dec 27, 2016Tutor
I'd be open to that except I can't be on the computer if the ehternet cable is pluged into the router. I'm recieving the internet via the router. Since it failed I have to plug the ethernet cable directly into the Mac.
