JonathanNetg
Oct 12, 2021Aspirant
WiFi range on Netgear Nighthawk Pro Gaming XR500
Hi, I recently purchased the Netgear Nighthawk Pro Gaming XR500. Very happy with it. One thing though, the WiFi range isn't that great for some reason. I don't have a large house, my modem is located ...
Oct 13, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NH Gaming router products. Most of the people who watch that forum are more likely to have experience with NH Gaming routers and know how to work it better than those of us who follow this "router" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
If you need additional wifi range or coverage, Ive found that EX7700/8000 wifi extenders work well with XR series routers.
Thank you.
- JonathanNetgOct 13, 2021Aspirant
Thank you so much. Will look into that for sure.
