JonathanNetg
Oct 12, 2021Aspirant
WiFi range on Netgear Nighthawk Pro Gaming XR500
Hi, I recently purchased the Netgear Nighthawk Pro Gaming XR500. Very happy with it. One thing though, the WiFi range isn't that great for some reason. I don't have a large house, my modem is located ...
JonathanNetg
I did look at the WiFi extended device but I though this Netgear XR500 is good enough for a standard house WiFi range. hmmmm..
Oct 13, 2021Guru - Experienced User
What size is the home and what are the interior walls made of?
Thats key.
Another key is placement.
The routers antennas broadcast omnidirectional and if you're router is located to one side of the home, half your coverage isn't getting used as its not directional. Any chance you can centrally locate it?
