Paperboy61
Sep 02, 2021Tutor
WiFi range
Despite have a really small house, I'm finding that in certain parts of the house, the WiFi is very weak or non-existent, and get almost nothing in the garden. Is there an easy/cheap way to extend th...
Paperboy61
Sep 03, 2021Tutor
Hi, only a small two-bed house, not sure of sq footage, but it's 200+ years old. I think where it was extended once there must be a huge RSJ because we have had problems at one end in the house, hence we bought the R7000. So what would you recommend as a solution in this case?
Sep 03, 2021Guru - Experienced User
Tough to say off that limited info.
It might take trying a few things so I'd check into purchasing things at a place with a decent return policy.
You can try a wireless extender and see if it works.
If it doesn't, then I'd look at a wireless powerline unit like the PLW1010 (or other versions)
