kharzan's avatar
kharzan
Tutor
Nov 29, 2020
Wifi replacement for ethernet switch
Hi there,   I currently have an ethernet switch (GS105 - https://smile.amazon.co.uk/gp/product/B0000E5SEQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1) which I use to connect to my PC in my stud...
  • CrimpOn's avatar
    Mar 29, 2021
    gabegarcia wrote:
    Is Obri blocking these DDoS attacks?
    I'm seeing about 10 attacks per day in the logs. I've checked their IP's and they are not the false positive scenarios like Facebook, Amazon, or Dropbox.
    Should I be concerned?
    Yes, Orbi's firewall does not accept connection attempts from the internet until the user deliberately sets up either port forwarding, Remote Administration, or OpenVPN.  These log entries are the result of firewall logic which collects connection requests and attempts to assign them to categories.  I monitor two Orbi systems and they both regularly log about 30 of these "attacks" every day. (Yes, every day.)  I have seen comments that Netgear's logic is flowed and logs things as "attacks" that are not.
    I do not recall seeing any "snmp" events in my log files.
    Be Concerned?  I think not.  If you would rather not see the entries in the log file, there is an option to stop logging them.
