Majuro
Jan 13, 2022Tutor
wifi router does not connect internet RAX20
My router started not connecting to internet. After I rebooted, it does not show SSID and completely unable to connect to internet. Somehow, I was able to connect to guest
Jan 14, 2022Guru - Experienced User
What router do you have? The RAX20 from your title or the RAX40 from your signature?
what firmware is on it?
have you tried a simple factory reset?
