bzhayes
Oct 22, 2019Aspirant
WIFI Router forcing me to sign-in
I just moved and having a difficult time setting up my WIFI. I have it hooked up from my cable modem to my router to my computer. Everything appears to working fine... internet is working on my com...
- Oct 28, 2019
Well, I got WIFI working but I am still not sure what was happening. My phone was finally able to connect to the activate.spectrum web page through my cellular network. It took a while because it was trying to connect through the WIFI network. On that page, I had to enter my account information (phone number and zip code associated with Spectrum). The Obee modem came up as hardware I needed to activate. I activated it and everything worked! This is really bizarre since the Obee modem was already activated and I was accessing internet through it without any problems. Once I activated it on one wireless device, WIFI worked on all devices (I didn't need to activate on each device).
I'm not sure how but it seems like Spectrum is doing something goofy to force people to buy WIFI though them. I'm just surprised their is not more information on the internet about it.
bzhayes
Oct 23, 2019Aspirant
Thanks for the reply!
The Spectrum Modem is an Ubee model DVW32CB. I don't know if it is bridged. There is a WIFI router built into the Spectrum modem, but Spectrum wanted to charge me for it monthly. That is why I bought the NetGear router, and it was working well at my old place. I thought maybe the router broker from the move so I bought a new one. Both are giving me the same problem.
Yes, I select the SSID for this Netgear router (xx replaced with the actual number default) it asks for the password. I enter it (the default). It connects and then says, "sign-in to network". When I select that it says "sign in to NETGEARXX". Below that the web address pops up for spectrum. There is a load bar which makes it about 3/4 of the way then stops. The rest of the screen is blank and nothing happens. There is a dropdown menu with 2 options: (1) do not connect to this network (2) use this network as is. Neither option helps me connect.
The Netgear router is AC1200 model R6120. I am not sure what the firmware is but it updated when I plugged it in and stated firmwear is up to date. Thank you so much to the help!
IrvSp
Oct 23, 2019Master
I've got Spectrum and if you are NOT paying the Wireless charge, it isn't on your account and the modem/router will not turn it on. Another check would be if you see an SSID from the modem/router. If you only see NETGEARxxx then you are probably OK, although the phone could see other local SSID's as well.
Default would be on the lower label on the router, is that what you used (I assumed during setup you never changed it?)?
Do not understand this? So you are prompted TWICE to sign-in to the network?
Let me be clear in what I think you did:
- Your phone needs to connect to Wifi.
- You open the Wifi settings and select an SSID that you know to be your router's SSID.
- You enter that SSID's passphrase.
- The you see "sign-in to network"?
Can you post a screenshot of this and what happens next? If you are already signed in AND connected, what is this showing on?
Wondering if something is being held within the phone? Have you tried FORGETTING the SSID and then trying to connect again?
- bzhayesOct 23, 2019Aspirant
Thanks so much everyone for the back and forth! I am somewhat comforted by the fact that people smarter than me are also befuddled by this. I will try to knock out a couple of the questions asked:
IrvSp wrote:Default would be on the lower label on the router, is that what you used (I assumed during setup you never changed it?)?
Yes, I am using all defaults from the label and have not changed anything at this time.
IrvSp wrote:Do not understand this? So you are prompted TWICE to sign-in to the network?
Yes, that is exactly what is happening. I will get a screen shot this evening when I get home. I would describe it like trying to connect to a WIFI network at a hotel where you first connect to the SSID and then you need to sign in. In this case the sign in page never actually comes up.
Thanks again for all of the help!
- IrvSpOct 23, 2019Master
bzhayes wrote:Yes, that is exactly what is happening. I will get a screen shot this evening when I get home. I would describe it like trying to connect to a WIFI network at a hotel where you first connect to the SSID and then you need to sign in. In this case the sign in page never actually comes up.
That is EXACTLY what I was thinking and why I'd like to see a screen capture.
When you get home, do this, with the PC directly wired to the router, go to the ROUTER LOGIN page (URL of 192.168.1.1, 192.168.0.1 or ROUTERLOGIN.NET, one of those should work) and go to the WIRELESS page and change one of the SSID's (use the 2.4Ghz as all devices should see it) and it's passwor. Then try to connect to that SSID. Although it is highly unlikely I was wondering if you actually were connecting to a different router?
What doesn't seem logical is the wired PC does have the 'challenge' to connect?
Where you lived before, was it also Spectrum? I'm thinking the phone connected to a HOTSPOT which would present that to you. Another reason why you should FORGET the connection and start over.
Thanks again so much for the help. I've tried most of this no avail, but I retried just to verify. It looks like I can only attach one image at a time, so I will take several posts to get everything up. Here it is before I connect to the default router setting NETGEAR46.
