Radahl's avatar
Radahl
Guide
Mar 22, 2018
Wifi router not visible
All off a sudden my WiFi isn't visible for any unit. Neither iPad, iPhone or my Dell laptop (Windows 8). I can do enything if the network cable is connected and when logging into the router it all l...
  • FURRYe38's avatar
    Mar 22, 2018
    What version of FW did you upgrade too?
    Do a factory reset on the router. Either from the routers web page or the back button.
    Check to see after the reset if your devices sees the default NG SSID names listed. Should see two. If so, go in and set up new SSIDs and give new PWs.
    Ensure that each radio is enabled as well under Advanced/Advanced settings/Wireless settings.
