Radahl
Mar 22, 2018Guide
Wifi router not visible
All off a sudden my WiFi isn't visible for any unit. Neither iPad, iPhone or my Dell laptop (Windows 8). I can do enything if the network cable is connected and when logging into the router it all l...
- Mar 22, 2018
What version of FW did you upgrade too?
Do a factory reset on the router. Either from the routers web page or the back button.
Check to see after the reset if your devices sees the default NG SSID names listed. Should see two. If so, go in and set up new SSIDs and give new PWs.
Ensure that each radio is enabled as well under Advanced/Advanced settings/Wireless settings.
schumaku
Mar 22, 2018Guru - Experienced User
WiFi switched off by hardware button? Check what the cat is doing overnight.
R9000 v1.0.3.10 does reliably keep the WiFi up and running here - and I've not seen many similar reports, too.
Radahl
Mar 22, 2018Guide
By the way...
Lost WiFi on V1.0.2.40 (belive it was...) and didn't regain on upgrade to V1.0.3.10.
Didn't until after hardware reset.
