BruiserB
Nov 08, 2020Aspirant
WiFi router recommendation request
I’m not totally satisfied with gaming ping and home coverage of the NETGEAR Nighthawk AC2600 Smart WiFi Router (R7450). What other netgear WiFi router would you recommend?
Nov 09, 2020Guru - Experienced User
How big is your home?
What are the interior walls made of and how many levels is it?
Most routers long ago were hitting their max transmit power. So if you're coverage isn't that great, an upgrade to another single router solution might not help any. it might be better to look at a mesh system (triband if you're needing low latency/high speeds).
BruiserB
Nov 09, 2020Aspirant
It is a wood stud/drywall, 2 story ranch with brick exterior. 1700 sq ft.
- plemansNov 09, 2020Guru - Experienced User
The exterior will block wifi so don't expect much for wifi external to the home.
Is 1700sq ft total or on each floor?
Is your router centrally located or is it to one side of the home?
The R7450 broadcasts omnidirectional meaning if its on 1 side of the home, half the broadcasting isn't doing much good.
And if the home is truly 1700sq ft, a single router solution *should* cover it. the only * part is things in the walls can block wifi. things like hvac, certain types of plumbing, or even foil lined insulation can block wifi/cause dead spots.
What modem/gateway do you have?
What speeds do you pay for?
What speeds do you get?
What is your ping/latency on a speedtest?
- BruiserBNov 26, 2020Aspirant
The wireless range is working fine. I am concerned about high gaming ping....i.e. 80-100ms pings when other players get 30-50ms pings. I am wired with the gaming desktop PC to the AC2600 Smart WiFi Router (R7450).
I use the R7450 to connect PPPoE to the fiber connection.
I pay for 40down/25up speed service.
I consistently test at the 40/25 range.
I get latency results of 6ms
- plemansNov 26, 2020Guru - Experienced User
If you hit the speeds you should and the latency you'd expect during speedtesting, then your increased ping during games is more indicative of where the game server is located. The further away it is, the higher the pings times.
