emmajan123
Mar 21, 2022Aspirant
Wifi Router
Hello, I want to know like some people say 3 antennas work better than 2. Kindly inform me that is it true or not?
Mar 21, 2022Guru - Experienced User
The problem is it usually isn't the routers antenna's being the bottleneck or causing issues.
Its your own devices internal antenna.
Most phones, tablets, pc's, etc are all 1x1 or 2x2 antenna devices.
And their internal broadcast power is usually less capable than the routers broadcast power.
A typical (not all) phone broadcasts a 15mW versus your router can transmit at up to 1W of power (depending on channel/band).
Its why sometimes its beneficial to turn down the broadcast power on a router and add extra access points.
emmajan123
Mar 22, 2022Aspirant
It Helped me a lot.đ
