sstoots
Dec 18, 2021Aspirant
Wifi security camera
I have a Soliur XS7 Pro Wifi Solar security camera. I have created a 2.4ghz SSID for the camera to access. Launching the camera app utility on my phone which is connected to the same 2.4ghz SSID....
Kitsap
Dec 19, 2021Master
sstoots wrote:Unless I am totally missing something, the Admin app for the NightHawk lacks the granularity to make any changes aside from renaming SSIDs, associating them with either 2.4 or 5ghz channels, or changing the password.
To configure your router and change settings, connect to the router via an ethernet cable and a real computer with a web browser. You are wasting your time with any other approach.
In the 2.4 GHz band configuration, look for 20/40 MHz coexistence and disable it.
sstoots
Dec 19, 2021Aspirant
I went in to router administration through the web (192.168.1.1) and toggled off 20/40 mhz coexistence. No change . Not being promoted through the camera setup app to select a SSID or associated credentials.
- KitsapDec 19, 2021Master
You might need to reset your camera to initiate the setup process again.
Did you power down and restart your router after making the changes?
sstoots wrote:I went in to router administration through the web (192.168.1.1) and toggled off 20/40 mhz coexistence. No change . Not being promoted through the camera setup app to select a SSID or associated credentials.
