Jeremeh
Oct 23, 2022Follower
WIFI SECURITY
Does wifi owner see's what app you're using
Oct 24, 2022Guru - Experienced User
I have no idea what you're asking or trying to do here.
A bit more details on what your question/problems is would help.
Along with what device you have.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
