Niching
May 21, 2021Aspirant
Wifi Signals Drop 3-4 in evenings daily
Hi: Our wifi signals have been dropping daily 3-4 times a night between 6:30pm - midnight and in the morning at about 6-7am. We reset both router and modem daily for about 1.5-2 weeks now. Spe...
microchip8
May 21, 2021Master
You might try an older firmware. NG has messed it up in recent releases. If I recall correctly, .42 version is still a recommended one
- ChrsteneMay 21, 2021AspirantI have same issue as the original post and would like to “downgrade” to 42 ...
Can I do this through my iPad or laptop? (The instructions state a wired connection recommended?- microchip8May 21, 2021Master
Can I do this through my iPad or laptop? (The instructions state a wired connection recommended?Always use a wired connection for something as critical as firmware update. WiFi is a good way to brick your router
- NichingMay 24, 2021Aspirant
Thank you. I will google or youtube to figure how to update the firmware. Somehow with the Nighthawk app, I thought it would automatically update the firmware.
