jbj123
Jan 08, 2019Aspirant
Wifi speed 66% lower than ethernet
My desktop is hardwired (ethernet) to my modem, passing through the router, and download speed is roughly 150bms, with upload roughly 10mps. This is consistent with what the ISP provides. However, us...
- Jan 11, 2019
Looks like that, single band, not dual.
Easy and fairly cheap to upgrade as long as you have a USB port. I have one... Amazon has many to choose from. $11 and up here. If you do get one, get one with at least 2 antennea's showing. Single one would have lower speed. If you want to be 'traveling' with the Laptop then the smaller mini or nano ones would work, just not as fast.
IrvSp
Jan 11, 2019Master
jbj123
Jan 11, 2019Aspirant
Thanks again very much! You have been patient and very helpful!
