Alexnguyen
Mar 04, 2023Follower
wifi speed going too much from 700 down to 90 for AC4000/ R8000P
Hi friends, I am using Netgear router AC4000 model R800P. wifi speed goes down from 700 to less than 100 MB per second after i had reset it. i have checked with link system router which remain the ...
Mar 04, 2023Guru - Experienced User
Speed testing with a wired PC?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
