Krit21
Dec 30, 2021Tutor
WIFI Speed not as fast as the SPeedTest results
Hi All, I need some help.....i have tested the speed at the router and have almost 300Mbps. I connect my iphone Xr to the wifi and ran a fast.com test and only get 12Mbps. i have researched ...
Dec 30, 2021Guru - Experienced User
Are you using smart connect?
What band are you connecting to?
If you hardwire a pc/laptop into the router, what speeds do you get?
What modem/gateway is the router connected to?
What firmware is on the router?
- Krit21Dec 30, 2021Tutor
Are you using smart connect? Yes, single wifi name
What band are you connecting to? 6,44,157If you hardwire a pc/laptop into the router, what speeds do you get? 340 Mbps avg
What modem/gateway is the router connected to? armstong cable modem, not sure of name
What firmware is on the router? V1.0.4.76_10.1.82
this is a recent speed issue, within the last 4 months.
