Brian_E72's avatar
Brian_E72
wifi speeds > 200mb?
Hello,
I have the r6700v3 router, and while connected via ethernet, I am getting the max our connection will allow, which is almost 450mb. The problem lies in the fact that when I connect with another device via wifi, I only get around 200-230mb/s. I'm only ~100ft from the router itself, have a very good signal and an excellent SNR. I have checked, and no other routers in range of our house are using the same channel.
I get about the same speeds in Linux as I do in Windows. I'm using a USB3 dongle that uses the Realtek 8812BU chipset. The link connection is well over 850mb/s. Bluetooth is off as well as power saving mode for the adapter.
Any suggestions would be appreciated!!!
Thanks!!
  • plemans's avatar
    Wireless AC will never hit gigabit speeds. it can get fairly close depending on the device you're testing on.
    A lot of the time its device dependant. A 1x1 antenna device is going to have half the throughput of a 2x2 antenna device.
    Also, distance makes a big impact. "only 100ft" is quite a significant distance when it comes to 5ghz. It doesn't broadcast nearly as far or through as much materials. it drops of very quickly with 5ghz.
    you can read many more details and in depth here: https://www.duckware.com/tech/wifi-in-the-us.html
    • Brian_E72's avatar
      Brian_E72
      I never mentioned gbit speeds......
      Ethernet connections to the same router consistantly max our our advertised internet speeds of ~400mb. It seems to me that this router is limiting wifi connections to ~200mb. The reason I say this is that I've also tested it within 2' of the router and never gotten any speeds above 230mb. I've been through every setting on this router, but yet cannot achieve the full 400mb that I should be getting when I'm right next to the router. Sorry I didn't include this information in my original post. And as mentioned, the link speed to the router is about 2.x* my maximum connection speed from the modem to the ISP.
      • PauLita's avatar
        PauLita
        Luminary
        R9000 + Galaxy S20 5g Ultra
