leep58
Dec 27, 2020Aspirant
Wifi very slow, download and upload .
For the last 2 weeks my Nighthawk has been very slow more so during peak times, 7/11pm. My provider said that it could be a line problem and that a contractor would be out to look for this. T...
michaelkenward
Dec 28, 2020Guru - Experienced User
leep58 wrote:
Yet when I am doing a speedtest via wifi via the Nighthawk its Downlaod and up load speeds are around 10% of the of capacity.
Wifi speedtests measure the speed of your wifi, not your Internet connection. And wifi speeds depend on the wifi device you are using. They are never as fast as your Internet connection, often by a large margin.
To test the router's Internet speed, you need to run a wired Ethernet test.
leep58 wrote:
I have tried changing channels EG: 6 or 11, this seems to make it slower.
That's to be expected. They are at 2.4 GHz, which is by definition slower than 5 GHz.
leep58 wrote:
The provider says that it is not there problem but the Netgear NightHawk. I beg to differ so I am asking for any help that maybe at hand to fix this ongoing problem.
The speed of your local wifi has nothing to do with your Internet service provider. If you get the speed you pay for out of its modem, then the network is fine.
