cahowell
Jul 13, 2021Guide
WiFI6 not showing on any devices that are compatible
Good morning, I have the new RAXE500 router upgraded from the XR500 and no matter what I do, I cannot get the WiFi6 network to show up. I know this is a WiFi6e router and I do not have any compatible...
- Jul 14, 2021A wifi 6 device will be able to use the RAXE's 2.4ghz and 5ghz signals. Not its 6ghz.
cahowell
Jul 13, 2021Guide
- plemansJul 14, 2021Guru - Experienced User
Unless you have a 6E device, the 6ghz band won't show.
The 2.4ghz shows as the standard epoch and the 5hgz (ax) as the epoch5
- cahowellJul 14, 2021Guide
Thank you and please forgive my ignorance, however I have several WiFi6 devices and one WiFi6e device (see photo.) Is the WiFi6e band not backward compatibe with devices that only support version 6 and not 6e? The SSID doesn't even show up on my 6e client with the latest chipset drivers installed from Intel and there aren't a lot of settings on the router itself for WiFi6e.
6E hasn't been showing up on any windows devices without work arounds because of some windows/intel issues.
I'd recommend reading through these for more info.
WiFi 6E Problems - RAXE500 - NETGEAR Communities
No trace of Wifi6 networks on Nighthawk RAXE500 - NETGEAR Communities
