APD1766
Nov 06, 2020Follower
WiFi/WPS lights not lit up
WiFi / WPS lights do not light up, even after pushing buttons. All else is normal. Thanks to all m
Nov 06, 2020Guru - Experienced User
On what?
You didn't put modem/firmware/nothing other than wps/wifi not lighting up.
most need to be pushed and held for 2 seconds.
but for more info, the manual would be beneficial.
go to netgear.com/support/ type in your model number. it'll take you to manuals, guides, firmware.
