ender23
Mar 16, 2016Aspirant
Will NetGear ever fix R7500 or should I get rid of it?
I have to reboot the router, just like everyone else, about every other day, to restore wifi and internet connectivity. Sometimes, twice in one day. All the sudden all the wifi connections to all d...
- May 27, 2016
Just an update. Seemed to have isolated at least why the router crashes/halts comms intermittently.
Originally, I decided to plug my external drive into the ESata port rather than one of the USB 3.0 ports.
I wanted to use ESata figuring it would be slightly faster avoiding USB encapsulation/conversion. Honestly I can't tell much different speed wise Esata vs the USB on the R7500.
Any way, a few weeks ago I decided to switch the external drive to the USB 3.0 port. Since then, I haven't had to reboot the router once.
Never had any issues with the Esata when directly connecting the drive to a Windows machine. So I'm not sure what is at error exactly. Could be the sata on the router, could be the drive enclosure. Could be the cable. (not spending further time on this)
Just figured maybe if someone else ran into a similar issue, they could try using the USB port versus the Esata, if they are using the Esata port.
VE6CGX
Mar 20, 2016Master
Compare the chip sets between R7500 and R7800. What do you think?
AlvaroIsaac
Mar 20, 2016Guide
My immediate impression is that the R7500 and R7800 are related but different enough that it is unlikely to have the same issues as the R7500 has in these forums. The R7800 is at the top of my list of replacement options for my R7500.
I see the R7800 has significant changes in specs over the original two X4 Nighthawks (R7500 & R7500v2). I used my R7500 as a basic NAS with daily backup of 4 computers to two separate drives...this was one of my favorite features and it worked well. The R7800 has a nice new CPU that should improve upon this functionality and leave plenty of room for more NAS/Server-like uses. The 2.4ghz band is finally 4x4 on the R7800 making it a full 4x4 and the 5ghz is upgraded. The guys at www.smallnetbuilder.com say:
The R7800 is the first product on the market to support 160 MHz bandwidth mode. Since there is not actually 160 MHz of contiguous bandwidth in the 5 GHz band available in consumer routers today, this is implemented as 80 MHz + 80 MHz.
160 MHz mode enables devices to basically double their maximum link rate. So a 2x2 STA 802.11ac STA that supports 160 MHz mode can have a maximum link rate of 1733 Mbps vs. the 867 Mbps it would normally have. Of course, like many of 802.11ac's high-bandwidth tricks, higher 160 MHz mode bandwidth requires a strong signal to work effectively.
I have two WNDR4500 routers that still work with little to know maintainence after YEARS of service (some of that spent in the attic of my Texas home running in 110+ degree temperatures). I thought the R7500 would bring me similar longevity and simplicity and I hope the R7800 will do just that.
