CurtisWalter
Jul 15, 2020Aspirant
will not connect to iaai.com. Will connect to all other sires.
Computer will connect to iaai.com when plugged straight into isp. Will not connect when router is connected and computer is connected through it. 4 technitions cannot solve. Have reset router normall...
- Jul 17, 2020
My 7th support agent finally was able to solve the issue.
Under Advanced > Setup > WAN Setup, He had me put a check mark on the NAT Filtering item and change it to Open.
The issue is now resolved.
CurtisWalter
Jul 16, 2020Aspirant
If I bypass the router with a computer directly connected to my BTES Fiber router it connects to https://iaai.com instantly.
It will not connect to https://iaai.com through the R7000P router.
The only reason I set up a Nord VPS was to troubleshoot the issue and yes the computer will connect to https://iaai.com through the VPN and the R7000P router.
So this tells me that the issue is with the router.
I will not set up a vpn in all the computers so we can access this site.
I hope I am clearer now.
CurtisWalter
Jul 17, 2020Aspirant
