DAG_cali
Aug 08, 2021Aspirant
Will pairing R7450 with EAX20 extender yield better wifi coverage than pairing with EX7000?
In other word: Do I need to have an AX-equipped device to see an improvement in Wi-Fi range when swapping out an EX7000 (AC1900) range extender for an EAX20 (AX1800)? The wifi signal from the router ...
- Aug 08, 2021
No.
Signal broadcast power wasn't increased with the AX spec.
So routers/extenders aren't broadcasting any further. Because of the increased speed, they can do a little better with reduced signal.
You'd be better off to invest the money in a hardwired connection between the 2 points
Aug 08, 2021Guru - Experienced User
No.
