txchuko's avatar
txchuko
Guide
Apr 20, 2016
Will simply unplugging router to reboot cause any long term damage to it?
my Belkin router had an option to schedule reboots by selecting days and times, and I would like something similar for my nighthawk ac2350 v2, to keep things smoother since i still reset my router oc...
  • netwrks's avatar
    Apr 20, 2016
    Using a timer is not an issue. Others do the same to various routers.
    EDIT: Basically the power button does the same thing. Just a cleaner way of cutting power to a device.
