dalonso66
Mar 20, 2021Aspirant
Will the Nighthawk 7800 support a poe switch?
I have a device that requires POE. I've connected that device to one of the LAN ports on my router (R7800). The problem is, I lose internet connection on my other devices when I plug in the POE swit...
DarrenM
Mar 22, 2021Sr. NETGEAR Moderator
It should support a POE switch are you using a normal ethernet cord to connect the router to the switch and not a POE one?
- dalonso66Mar 22, 2021Aspirant
Thanks for the response, I forgot to update my post.
It seems the issue has worked itself out. The PoE injector is indeed working with the router.
Thank you.
