trinityfishkill
May 11, 2022Aspirant
Will this router work after the switch to IPv6?
I have a Fios Router Model Fios-G1100. Will this router work after the switch to IPv6?
Thanks!
Dave
May 11, 2022Guru - Experienced User
Not sure why you're asking about the g1100.
Do you have a netgear router?
- trinityfishkillMay 11, 2022Aspirant
We received an email from Verizon (see below). Our other router is a Fios-G1100 model. It is not clear from Verizon's email if that model will work after the upgrade adding support for the IPv6 discussed in the email below.
Dave
Account number ending in: 800-0001
Hello,
Verizon is upgrading our Fios Internet network to provide our business customers with dual stack dynamic IPv6 /IPv4 addressing. We will continue to maintain support for IPv4 while adding support for IPv6. We anticipate the upgrade to take place in your area on or after June 5, 2022.
In order to prepare for this upgrade, please review your router security settings to make sure the network is protected from possible intrusion.
Currently, the only Verizon provided routers that support IPv6 are the Fios Router and the Fios Quantum Gateway. To determine which router you are using, click or visit the links below and review the contents:• Fios Router - verizon.com/fiosbusinessrouter • Fios Quantum Gateway - verizon.com/fiosquantumtroubleshooting
If you have one of the Verizon provided routers listed above, we recommend a firewall security setting of Medium or above (Medium is the default setting of the router). In order to verify your current settings, connect to the router through your computer by logging into myfiosgateway.com or typing 192.168.1.1 into a browser session and authenticating with the password found on the side of the device. Please click or visit the appropriate link above for further instructions.
If you’re providing your own router, we recommend that you check with your router's manufacturer to determine if it supports IPv6 and for information on appropriate security settings.
If you would like more information on IPv6, including FAQs, please click or visit verizon.com/ipv6faq.
Thanks,
Your Verizon Team- FURRYe38May 11, 2022Guru - Experienced User
If this is only in reference to Verizon's router, you'll need to contact Verizon for help and information regarding there product.
If you have NG router, please state the model you have.
