trinityfishkill
May 11, 2022Aspirant
Will this router work after the switch to IPv6?
I have a Fios Router Model Fios-G1100. Will this router work after the switch to IPv6?
Thanks!
Dave
May 11, 2022Guru - Experienced User
Not sure why you're asking about the g1100.
Do you have a netgear router?
trinityfishkill
We received an email from Verizon (see below). Our other router is a Fios-G1100 model. It is not clear from Verizon's email if that model will work after the upgrade adding support for the IPv6 discussed in the email below.
Dave
Account number ending in: 800-0001
- FURRYe38May 11, 2022Guru - Experienced User
If this is only in reference to Verizon's router, you'll need to contact Verizon for help and information regarding there product.
If you have NG router, please state the model you have.
