rajpaalsinha
Apr 02, 2025Aspirant
Will upgrading my Nighthawk R7800 extend range?
I've been using the R7800 for years and it's been good. I was on our side yard setting up Lumary wifi controlled lights and a TV in a new outdoor bar. My phone was able to find the wifi but kept losi...
michaelkenward
Apr 02, 2025Guru - Experienced User
rajpaalsinha wrote:
Currently the routers signal has to travel through 3 internal and 1 external walls to reach my side yard area.
Bit of a stretch. And the R7800 doesn't have the latest and greatest wifi technology.
Any way of moving the router earler to the yard area?
If you are etending your network it might be worth lpookinh onto Netgear's Various Mesh systems.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
Disclaimer: Just another user with time on their hands.
