bugslovertoo
Dec 22, 2016Aspirant
Win 7 usb control center guest account won't print
Hi
I have an issue when trying to print from a guest account on which the USB CONTROL CENTER is installed on the admin account. I can print from the admin account, but not the guest account. Interestingly, when I try to print from the guest account and nothing happents, if I log off, and then log onto the admin account the document prints. I have looked to solve this problem but have yet to find the answer. This is my last hope!
Thanks for your time.
Hi bugslovertoo,
Check your Guest account as it might have restrictions with local network.
- JamesGLNETGEAR Employee Retired
Hi bugslovertoo,
Hi bugslovertoo,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- bugslovertooAspirant
Thank you for your reply.
The account name I gave was misleading. It is a standard user account . I checked the internet properties and saw that the network connection was, for some reason, a public network. I changed it to home, since it is my home, and voila! I can print.
Thanks for your help.
