Trigen
Nov 27, 2020Aspirant
Windows 10 2004 A6210 Constant disconnects waking from sleep and extremely poor performance.
Windows 10 2004 Asus 270E gaming i7700K Hello the last 6-12 months this A6210 usb WIFI has gotten worse and worse with windows 10. Im not sure what update does it but there is no difference wit...
Trigen
Thank you for the quick reply. Im afraid any of the standard answers ive seen work. . Its not allowed to turn it off and everything else is at high performance. As for the placement of the topic oddly It would not let me choose any other section than the 3 nighthawk ones after several attempts but i see placing it directly there to begine with does work.
michaelkenward
Nov 27, 2020Guru - Experienced User
Trigen wrote:
Thank you for the quick reply. Im afraid any of the standard answer does not work.
That's not "the standard answer". There is no such thing. It is just one thing to investigate.
If it doesn't work, then I'd still delve into Windows.
To get more help you will have to be a bit less cryptic in the information you provide.
