LicensedNERD's avatar
LicensedNERD
WINDOWS 10 reports NO INTERNET but there is
Using my new R7900 with Windows 10, firmware v1.1.0.4, NO INTERNET is reported but there is.  I can use all browsers and surf anywhere, with either wi-fi or Ethernet. Both report NO INTERNET.  Micros...
  • Snows's avatar
    Snows
    Nov 17, 2016
    Ok I had the same problem I do not own your router But Go to the Properties of your NIC's then go to  Configure of all your NIC's and make sure if you have it, a Power management tab, go under this tab and  turn off all power management stuff  Like Respond to ARP Requs, Respond to NS Requs, Ect. turn  off All Power saving options also turn off all wake on lan I own a Netgear WNDR4500 as a WAP. This fixed the probmel  WIn10 has been doing some fishy stuff when it comes to updates turning porwer and privcy options back on after a update.. Thinks Windowns. Hopefully this fixs your problem. this is for win 10/8.1 os
