LicensedNERD
Jun 26, 2016Aspirant
WINDOWS 10 reports NO INTERNET but there is
Using my new R7900 with Windows 10, firmware v1.1.0.4, NO INTERNET is reported but there is. I can use all browsers and surf anywhere, with either wi-fi or Ethernet. Both report NO INTERNET. Micros...
- Nov 17, 2016
Ok I had the same problem I do not own your router But Go to the Properties of your NIC's then go to Configure of all your NIC's and make sure if you have it, a Power management tab, go under this tab and turn off all power management stuff Like Respond to ARP Requs, Respond to NS Requs, Ect. turn off All Power saving options also turn off all wake on lan I own a Netgear WNDR4500 as a WAP. This fixed the probmel WIn10 has been doing some fishy stuff when it comes to updates turning porwer and privcy options back on after a update.. Thinks Windowns. Hopefully this fixs your problem. this is for win 10/8.1 os
LicensedNERD
- My firmware is V1.0.1.4_10.0.12
- I DO have internet connection, but Windows reports it doesn't.
Windows IP ConfigurationHost Name . . . . . . . . . . . . : LicensedNERD
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : NoEthernet adapter Ethernet:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe FE Family Controller
Physical Address. . . . . . . . . : D0-BF-9C-9F-7F-CC
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : YesWireless LAN adapter Local Area Connection* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 34-E6-AD-45-BA-97
Autoconfiguration Enabled . . . . : YesWireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Dual Band Wireless-AC 3160
Physical Address. . . . . . . . . : 34-E6-AD-45-BA-96
Link-local IPv6 Address . . . . . : fe80::65f9:5a57:e872:e82d%6(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.17(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Sunday, June 26, 2016 2:16:13 PM
Lease Expires . . . . . . . . . . : Monday, June 27, 2016 4:34:05 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 221570733
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1E-2A-2F-7C-D0-BF-9C-9F-7F-CC
DNS Servers . . . . . . . . . . . : 8.8.8.8
NetBIOS over Tcpip. . . . . . . . : EnabledTunnel adapter isatap.{8EB6D447-28CC-42E3-8FDF-F8BB44D569ED}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes- Here is a screen shot of the settings
I can use ANY browser to surf the internet with wi-fi or connecting to router with Ethernet cable, even though the icon on the lower right shows a warning that I'm NOT CONNECTED.
THANK YOU for helping me.
IrvSp
Jun 26, 2016Master
It will take some time for the screen capture to appear, but you DO have a connection, copied from your IPCONFIG output:
Your Ethernet Adapter IS NOT connected though. You are using your WIRELESS connection.
Use the browser and put in 192.168.1.1, then enter admin and password for the ID and P/W and look at the connected devices.
