DatBoi
Oct 18, 2016Aspirant
Windows 10 says no Internet, secured however I do have Internet
Okay. I have looked for almost a year now since about a month after I got the free update for windows 10. My laptop for school originally had windows 8.1 preinstalled, but had the free upgrade to Win...
- Oct 20, 2016
It also came up here before:
WINDOWS 10 reports NO INTERNET but there is - NETGEAR Communities
Much more here:
windows 10 reports no internet access - Google Search
DatBoi
Oct 20, 2016Aspirant
Thank you you are correct that's the problem. I don't know why it is happening since I only see this on other Windows versions, but not 10. I've gone on other forums and posted this.
Thanks
Thanks
- michaelkenwardOct 20, 2016Guru - Experienced User
DatBoi wrote:
...I only see this on other Windows versions, but not 10. I've gone on other forums and posted this.I'm even more confused. At first you said that Windows 10 was the problem now you say that it is everything else.
