ffratea
Jul 06, 2021Aspirant
Windows 7
Trying to connect an old laptop running windows 7 to my WiFi.. Windows 7 needs a certificate? How do I correct this? Thanks
Jul 06, 2021Guru - Experienced User
well this wasn't very detailed.
How are you attempting to connect it to wifi?
What wireless adapter?
what router are you connecting it to?
Whats saying you need a certificate?
better descriptions/photos/screen shots will help us to help you.
ffratea
Trying to connect via wifi. Windows 7 is looking for a certificate to connect to my router. Windows 7 laptop seems to see my network but popup window when I try to connect states cant find a certificate
- plemansJul 06, 2021Guru - Experienced User
You still didn't tell us much info like what router your connecting to, what wireless adapter you're using (unless you're indicated by the a7000 in your signature).
but if you do a quick google on your issue, this is the first result.
https://www.tp-link.com/us/support/faq/255/
and the 2nd.
- ffrateaJul 06, 2021Aspirant
Network adapter is a Broadcom 802.11b/g Wlan 1394NetAdapter on thw windows 7 laptop. Nighthawk 7000 router
