ffratea
Jul 06, 2021Aspirant
Windows 7
Trying to connect an old laptop running windows 7 to my WiFi.. Windows 7 needs a certificate? How do I correct this? Thanks
ffratea
Trying to connect via wifi. Windows 7 is looking for a certificate to connect to my router. Windows 7 laptop seems to see my network but popup window when I try to connect states cant find a certificate
Jul 06, 2021Guru - Experienced User
You still didn't tell us much info like what router your connecting to, what wireless adapter you're using (unless you're indicated by the a7000 in your signature).
but if you do a quick google on your issue, this is the first result.
https://www.tp-link.com/us/support/faq/255/
and the 2nd.
