gjhodgson
Feb 28, 2021Initiate
Windows states 650 mbps connection, but my throughput is only 55mbps
My netgear EX8000 shows as giving a very good connection throughout my home - usually between 650 to 750mbps on 5GHz AC anywhere in the house. However, test using a file transfer and I only achie...
- Mar 05, 2021
The problem has been resolved - it was due to the use of old drivers for my Intel WiFi card in my laptop. Now that the drivers have been updated I get the same throughput (i.e. around 40mbps) from my Internet service provider regardless of if my laptop is connected via WiFI or via ethernet. File downloads over WifFi are also much quicker.
Thanks - I wouldn't have guessed it was a driver problem though since my laptop always showed a good connection speed (which was missleading). Anyway, everything is working great now.
michaelkenward
Mar 01, 2021Guru - Experienced User
What Internet speed are you paying for?
The EX8000 may show great speeds on the Internet network, from device to device, but going out to the Internet depends on the service you get.
gjhodgson
Mar 05, 2021Initiate
