ivanabq
Jan 16, 2022Aspirant
Windows won't allow Private network after installing Nighthawk CAX80
I have 2 machines running Windows 11 Home. After a recent upgrade of my cable modem and router to a Nighthawk AX8/8 (CAX80), Windows will no longer retain the change in designating the network as Pri...
Jan 16, 2022Guru - Experienced User
I'm not sure how you think a windows settings not being retained is related to the router.
ivanabq
Before installation of the CAX80 the network setting on both machines was Private. After installation, both were set as Public. Since no OS or other software change occurred, a causal relationship must be suspected.
- plemansJan 17, 2022Guru - Experienced User
when you change networks, windows default setting is for a public network with all new networks.
Thats it trying to protect your data. But you have to go in and change it.
If windows isn't letting you change it, thats a problem in windows.
- michaelkenwardJan 17, 2022Guru - Experienced User
Yup.
Which version of windows?
Windows 10?
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
Windows 11?
- Ethernet
- Properties
- Private
