timmehtimtims
Aug 05, 2021Tutor
Wired connection limited to 100mbps
I have attached my Nvidia Shield to the router via ethernet (about 5meters Cat5e), however the speed is capped at 100mbps. The Shdield is connected to LAN port 3 and the LED on the front of the D7000...
- Aug 05, 2021
another thing to check, if you have other gigabit devices, connect them to that port on the router and see if its a port issue. If the port is connecting other devices at gigabit speeds, the ports working.
If its just the shield, it kind of isolates it to either the cable or the shield itself.
Aug 05, 2021Guru - Experienced User
What actual shield do you have? there are multiple models
Have you tried a different cable? Sketchy cat 5e cables have caused issues before.
timmehtimtims
Aug 05, 2021Tutor
It's a 2017 shield which is capable of gigabit.
I've just bought the 5e cable so it's brand new. I'll try another though to whittle out the problem... I just assumed that it wouldn't work at all if the cable was faulty.
- plemansAug 05, 2021Guru - Experienced User
- timmehtimtimsAug 05, 2021Tutor
After all that, it seems to be a dodgy new cable... boo!
Thanks for your help :)
- plemansAug 05, 2021Guru - Experienced UserGlad you got it working! If you mark it solved, it might help the next person
