Dtrain84
May 24, 2021Aspirant
Wired devices cannot connect to the internet
If I try to connect a device to the router via ethernet cable, whether it be a laptop or another device, I cannot connect to the internet using that wired device. The Nighthawk app lists the wired...
May 24, 2021Guru - Experienced User
What modem do you have?
what firmware is on the router?
