dbehremo's avatar
Mar 07, 2017
Wired Ethernet line to pc is running at 100mbps instead of 1gb
I just connected my pc via ethernet cable (Cat5e) to the nighthawk r7000.  It blinks red and is running at 100mbps, instead of 1 gb.   The troubleshooting steps I have already done are as follows. ...
  • dbehremo's avatar
    dbehremo
    Mar 09, 2017
    Okay so I purchased a ethernet cable tester, turns out the cable was indeed bad.  I went ahead and created a new cable, and it does have a gigabit connection.
    Lesson learned dont trust your laptops lan port, try more than on device, and most likely it is the cable.
