dbehremo
Mar 07, 2017Tutor
Wired Ethernet line to pc is running at 100mbps instead of 1gb
I just connected my pc via ethernet cable (Cat5e) to the nighthawk r7000. It blinks red and is running at 100mbps, instead of 1 gb. The troubleshooting steps I have already done are as follows. ...
- Mar 09, 2017
Okay so I purchased a ethernet cable tester, turns out the cable was indeed bad. I went ahead and created a new cable, and it does have a gigabit connection.
Lesson learned dont trust your laptops lan port, try more than on device, and most likely it is the cable.
dbehremo
Mar 08, 2017Tutor
I tried to look for one but didn't see anywhere that I could change the speeds.
- William10aMar 08, 2017Master
I remember of a past posting that a 10/100mb lan had problems with the a netgear's 1gb port they could only get a very low speed on that lan feed. It was a older lan card the poster had but the 1 gb switch fixed the issue I can see a possible that new and old want to fight the switch seem to stop them. I understand that a gb lan port on a older computer should be the same standard as today but some how they do not also see eye to eye and go to war.
- dbehremoMar 08, 2017Tutor
The NIC card that is on the motherboard is only 3 years old tops.
- StephenBMar 08, 2017Guru - Experienced User
If you have another ethernet cable, then I suggest you try that. Though I suspect it will behave the same way (based on the other tests you've run) it's still worth a try.
dbehremo wrote:
I tried to look for one but didn't see anywhere that I could change the speeds.Try selecting the adapter in the windows device manager. With Intel NICs there often is a "Speed & Duplex" settings included in the "advanced" tab of the NIC properties.
If you see a setting for "energy efficient ethernet" (or similar wording) try turning it off, and see if there is any difference.
Okay so I have found it
It is a intel r I218-V adapter
It is under advanced
I found 2 interesting things one is gigabit master slave mode, which is set to auto detect. And Speed and duplex which is set to auto negoitaite
I do not know what that first one is but ill try chaning the second one and see if anything happens
I don't think it'll matter, but the manual setting for "gigabit master slave mode" would be slave. If it makes no difference, set it back to auto-detect.
