dbehremo
Mar 07, 2017Tutor
Wired Ethernet line to pc is running at 100mbps instead of 1gb
I just connected my pc via ethernet cable (Cat5e) to the nighthawk r7000. It blinks red and is running at 100mbps, instead of 1 gb. The troubleshooting steps I have already done are as follows. ...
- Mar 09, 2017
Okay so I purchased a ethernet cable tester, turns out the cable was indeed bad. I went ahead and created a new cable, and it does have a gigabit connection.
Lesson learned dont trust your laptops lan port, try more than on device, and most likely it is the cable.
William10a
Mar 08, 2017Master
I remember of a past posting that a 10/100mb lan had problems with the a netgear's 1gb port they could only get a very low speed on that lan feed. It was a older lan card the poster had but the 1 gb switch fixed the issue I can see a possible that new and old want to fight the switch seem to stop them. I understand that a gb lan port on a older computer should be the same standard as today but some how they do not also see eye to eye and go to war.
dbehremo
Mar 08, 2017Tutor
The NIC card that is on the motherboard is only 3 years old tops.
