dbehremo
Mar 07, 2017Tutor
Wired Ethernet line to pc is running at 100mbps instead of 1gb
I just connected my pc via ethernet cable (Cat5e) to the nighthawk r7000. It blinks red and is running at 100mbps, instead of 1 gb. The troubleshooting steps I have already done are as follows. ...
- Mar 09, 2017
Okay so I purchased a ethernet cable tester, turns out the cable was indeed bad. I went ahead and created a new cable, and it does have a gigabit connection.
Lesson learned dont trust your laptops lan port, try more than on device, and most likely it is the cable.
William10a
Mar 08, 2017Master
The only premade cables I have I found in box computer parts gotten to me one of them a 200 feet cat 6 patch cable I like to use the b standard when I put my cable together and less then cat 6.Glad to hear that get the problem fixed.
dbehremo
Mar 09, 2017Tutor
- William10aMar 09, 2017Master
A lan cable tester is your best friend when a cable is in question can save hours of trouble shooting when a piece of copper wire has a problem. I have been there before and learned my lesson the hard way it took a whole day before I replaced a brand new just out of the bag lan cable with another one just to find out the first one was bad saying to myself all the time that first cable has to be good it is brand new.
