wired-network
Oct 23, 2021Aspirant
Wired network on a RAX 20 not working
Hello, One-and-a-half years ago I bought a RAX20 — 4-Stream AX1800 WiFi 6 nighthawk router. I picked this router because it had 4 ethernet ports on it, and I wanted to hook certain devices up usi...
cscott1
Oct 23, 2021Guide
Might be the firmware became corrupt. I recomend force updating the firmware again if that doesnt work maybe try a rollback to a previous firmware that was working for you.
- wired-networkOct 23, 2021Aspirant
Hi,
I tried to update the firmware, and then downgraded to V1.0.2.82_2.0.52 and did a factory reset. However, this has had no effect. The light on the router still burn, but its not actually providing an internet connection over the cable.
