DanJosef
Jul 12, 2021Aspirant
Wired printer won't show up on Nighthawk R7000P
I am unable to get our HP LaserJet 1505n connected over the LAN to our Nighthawk R7000P router.
- The printer works fine when connected to a PC via printer cable.
- When I connect it to our router using a known working ethernet cable. The green light is on on the printer ethernet port, and the router light indicates the device is connected.
- In our router admin page, we do NOT see the printer listed as a connected device.
We need to see the device in the admin page to be able to know its IP address.
Any recommendations for next steps?
What does "printer cable" mean to you? Parallel? Serial? USB?
Other?> [...] The green light is on on the printer ethernet port, and the
> router light indicates the device is connected.Which "the router light indicates" how? I believe you, but a less
vague description would inspire more confidence.> - In our router admin page, we do NOT see the printer listed as a
> connected device.History? Is the printer configured with some wrong-subnet (static?)
IP parameters?> We need to see the device in the admin page to be able to know its IP
> address.
I'd bet that you're wrong about that.> Any recommendations for next steps?
Step zero:
https://en.wikipedia.org/wiki/RTFM
I'd visit hp.com , and get the documentation for that printer. If
some other device works when connected to that router port, then you
have a printer question, not a router question.I'm too lazy to do the research, but I'd guess that it can be
instructed (manually) to print a configuration page which would include
its IP parameters. I'd also guess that it could be reset in a way which
would persuade it to use DHCP (again?), which might be enough to make
everyone happy.- DanJosefAspirant
Thanks for your response, and for helping make the scenario more clear.
Other?USB printer cable.
> vague description would inspire more confidence.The light on the router is an orange light that occasionally blinks. It has the same look/pattern as the other two working connected devices on this router (a phillips Hue, and an Arlo hub).
> IP parameters?I have had the printer for over 10 years. I don't recall if it was previously wired successfull as we have been using the USB printer cable for at least 6 years. Unfortunately I don't have a way of checking the ip configuration because there is no screen on the printer.
> everyone happy.Thanks for pushing me in this direction! This printer has no screen, so the only way to see the ip configuration is to print a manual test page. But, for some reason the printer hasn't been able to print a test page in a long time (even though it works fine printing over that USB printer cable). It just clicks once when I try to print the test page and then does nothing.
So, I poked around a bit about this and found this: https://h30434.www3.hp.com/t5/Printers-Archive-Read-Only/HP-LaserJet-P1505n/td-p/2690 . TLDR; you can reset the network config by holding red/green buttons for 6 seconds while powering up. Once I reset the config I was able to print a test page, and now it shows up in attached devices in the router admin.
Thanks for helping me think of it as a printer issue :-).> Thanks for helping me think of it as a printer issue :-).
Thanks for the update. Blame shifting is one of my specialties.
Now that it's using DHCP (I assume), depending on the software which
talks to the printer, you might find it helpful to reserve an IP address
for it on the router (DHCP server), so that it doesn't wander around.
(_That_ would be a router question, but the same basic technique
applies.)Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Address Reservation".
