Stroopwafel
Mar 04, 2018Aspirant
Wired Speeds R7000
We have the R7000 for a while now and I noticed that after upgrading to 750Mbit connection, the router doesn't go higher than 350 capped. Directly into the modem does 750/750 without any problems...
- Mar 08, 2018Case850, I would love to test everything, only problem is that our ISP is blocking out the option to bridge the Draytek, they just simply don't allow it, it's greyed out. Probably it's because our television is also running through the same modem.So I think that means i'm stuck at AP mode, until they either give us more options or another modem.An older Firmware didn't do the trick for me, but that was two days ago when the whole infastructure was giving headaches, so I could give that a try again soon.
Mar 06, 2018Guru - Experienced User
Will have to contact NG support. Might ask them to see if there is any beta FW builds available that you can test.
There was one person on here who got speeds after doing a factory reset and not touching or configuring QoS, Traffic Meter and Acess Controls. Seemed to work for him.
Stroopwafelwrote:We have the R7000 for a while now and I noticed that after upgrading to 750Mbit connection, the router doesn't go higher than 350 capped.
QoS is off, tried a complete factory reset but still nothing.
Stroopwafel
Mar 08, 2018Aspirant
A little update,
I unplugged everything, for an hour. After that I connect the router to the modem, turned modem on, when it was ready, the router.
When the router was ready, I plugged in my pc and had 500mbit.
That was without touching anything, so I decided to set the router to AP mode, and voila, 750Mbit.
So the router is fine, but the other PC still only has 400mbit, even with other cables. So my guess is that the onboard NIC is faulty.
Gonna buy a seperate PCIe card for that pc to see if that terminates the problem.
R7000 is still rocking ;)
- FURRYe38Mar 08, 2018Guru - Experienced User
Glad you found the problem.
Enjoy. :smileywink:
Stroopwafelwrote:A little update,
- duckwareMar 08, 2018Prodigy
"so I decided to set the router to AP mode, and voila, 750Mbit."
Does your modem allow for multiple users? Turning off the router (turning on AP mode) means no NAT, no SPI, etc -- just a Gigabit switch with wireless built-in.
Sounds similar to results seen at duckware.com/testwan2lan
He's got a modem/router combo unit that he mentioned.
duckwarewrote:"so I decided to set the router to AP mode, and voila, 750Mbit."
- StroopwafelMar 08, 2018Aspirant
Yea router-modem without the option to Bridge it. ISP disabled it, best result in AP Mode. Router mode just notches it down 250mbit.
