cjsmall
Mar 05, 2021Initiate
Wired throughput of a WNDR3700?
 Router: WNDR3700v2 100NAS  Firmware: V1.0.1.14     I have a LAN with a TP-LINK gigabit switch attached to this router, which is attached to an Xfinity XB7-T cable modem. The LAN DHCP wifi is restrict...
- Mar 08, 2021I'd be betting on it being the bottleneck. when the WNDR3700 was released 12 years ago, netgear claimed it hit wired speeds of up to 500mbps. It had a gigabit port but at that time, not many devices could hit full gig speeds. And if an ISP was offering gig speeds, it was through business class setups. Smallnetbuilder did a review and test on it 12 years ago when it was released. I'd take a read through through that but they were maxing out around the speeds you're hitting.
michaelkenward
Mar 06, 2021Guru - Experienced User
So, the order is modem > router > switch? (I ask because one recent user seems to have modem > switch > router.)
Some stuff I find in Google describes the XB7 as a gateway, in other words a modem/router. Is yours a modem only variant?
The WNDR3700 does do gigabit but it is pretty old (2010).
Of course, wifi speeds will never get anywhere near gigabit and wifi won't be up to much either.
cjsmall wrote:
I have 1,000 Mbps internet service, but I can get no more than around 430 Mbps throughput max.
What speeds do you measure from the XB7, before it hits the WNDR3700?
