bkelly1369
Dec 22, 2021Tutor
Wireless Access Point definition
I am not finding the name of the type of device I need. I found this article: What is an Access Point and How is it Different from a Range Extender? (linksys.com) and nothing fits. I have a worki...
Dec 22, 2021Guru - Experienced User
When you say you "don't need a repeater", the problem with this is in reality you do.
A device can't be just a receiver, it has to send and receive. This means it also acts as a repeater if you so choose.
You can choose not to connect devices to it wirelessly and just use its ethernet ports. This would achieve the objecting you are trying to do.
You could use an access point that has a repeater mode or you could use a simple wireless extender.
bkelly1369
Dec 22, 2021Tutor
Call the two devices CR for computer room router (which is also wireless) and G for garage. The G device does not need to connect to any wireless device but the CR. It does not send the signal any further. Yes, I am aware that the G devices sends and receives, but the wireless part of it connects only to the CR. The goal is not to extend the wireless network from the garage, just access the existing network. The names still do not make sense to me.
How about this? An Ethernet switch that can join a wireless network.
Still, what device do you, dear reader, reccomend? The D-Link DAP 1665 did work, so maybe order another one. But prices have about doubled in the last two years.
Edit: just saw this name: Wireless Base Station. That seems to fit.
