Bobski2000
Feb 22, 2018Tutor
Wireless connection limitations
Hi, Does anyone know what the maximum number of wireless connections the router can handle please? regards dave
- Feb 26, 2018
Hi Bobski2000,
Router can accommodate upto 32 wireless clients per band.
https://kb.netgear.com/24043/How-many-clients-can-you-connect-wirelessly-to-a-NETGEAR-router
Bobski2000
Feb 22, 2018Tutor
Hi,
No wireless connections to the router. I have a sky q box and sky told me that 16 was the maximum, anymore and it’ll start causing problems.
in today digital environment, 16 is sooo low. Everything in the house that can be joined by Ethernet, is joined by Ethernet. But, as you can imagine that’s not helpful with 5 of us. 5 mobile phones, iPads ps3 and 4’s it all starts adding up. So wondering if to use the NETGEAR router as DHCP, as sky won’t let me use third party equipment.
hope I’ve made myself a little clearer
regards
dave
antinode
Feb 22, 2018Guru
> [...] I have a sky q box [...]
That tells me very little.
> [...] So wondering if to use the NETGEAR router as DHCP, [...]
Huh? "DHCP"? Are you talking about using the R7000 as a wireless
access point (connected by wire to the "a sky q box")? That might help,
by spreading the wireless connections to another access point.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "Use the Router as a
Wireless Access Point".
- Bobski2000Feb 27, 2018TutorSo sorry, been away on business.
I was thinking of using it as an acsess Pinot, so yes.
This is because my satellite company will not let me use another router other than theirs.
